Greater Houston Hamfest
0800 Listen to the SEC dazzle you with statistics regarding the STX section
0900 Listen to the SM dazzle you with information from the league.
Renew your ARES badge, if needed, at the ARRL table in the main vendor area.
Jeff, and all others…
In addition to having folks get their ARES Badge, how about have a PC/Laptop available so folks can update their ARES Vault info?
I know some can do it from home, but others may need help in password recovery…
For those at home, follow this link to the STX ARES Vault, where the ARES Database is kept…
https://www.stxares.org/vault_area/vault_gateway/site_gateway/vault_gateway.php
Login and if you forgot your password use the Forgot password link at the bottom of the page…
Select the Update Member Profile link…
Update any missing or wrong items
  • Please, do not use ALL CAPS…
Address
  • This is so we know where you live in case we need to send somebody to check on you, help you, or pick you up…
  • Do not use a PO Box unless you can get to the post office with all your gear and supplies for a 72-hour deployment…
  • Oh, we will need the address to the Post Office too…
Phone numbers
  • Please use 512-555-1234 format
  • 5125551234 is hard to read/type on a phone, use hyphens
  • Do not use N/A, Retire, None… Just phone numbers…
  • We have close to 100 members that do not list ANY PHONE NUMBERS???
  • If your Work number requires an extension, use this format: 512-555-1234 Ext 1234
Email address
  • Do not use @arrl.net address as they fail
  • Use the same email address used for our Primary Email Group on Groups.io
Check boxes, Power available, and capabilities…
  • Check that all the correct ones are checked…
  • Check your affiliations…
Emergency Contact Info
  • Check that it is 100% correct
Remarks:
  • Notes to yourself, EC, DEC, SEC…
  • Last updated 19-Feb-26
Even if nothing changed, select the Update button
  • This updates the Last Updated field of the database…
  • This tells your EC, DEC, and SEC when your data was last updated…
  • Some have NEVER pressed this button since joining X-years ago…
  • If your data is over a year old, we can’t trust it…
  • Get in the habit of doing this every year before the SET…
Ask your ARES members if they’ve updated their information…
73 Dallas N4DDM
We will have both Command Trucks on-site with multiple computer terminals. More than willing to let ppl use them & we can guide them through updating the Depot..
