I’ve got an older handheld I’ll be using for the marathon next weekend and need some assistance on how to program it to use the 147.00 output PL tone for the race. Any help is greatly appreciated.
73
KE5PCE
Jon
Knowing the model would help.
Jeff KE5FGA
He said it was an IC-T90A in the subject.
See the attached manual, page 70..
'73 (Best Wishes, for non-Hams)
WA5LEE
**Lee Glassman, ARRL VE, COM-L, COM-T, NREMT #**E3525310
Tomball, Texas
Pronouns: Him/He
MS150 Command Post Manager
Buffalo Bayou Regatta Communications Lead
Hamshack Hotline 12019
Allstar Node 58417
Houston Methodist Willowbrook Hospital EMCOMM Team
Tomball FD EMCOMM Team Lead
PA Digital Radio Group NCO
Texas Lonestar DMR Network NCO
OMISS #1198
TDXS #219
ZOOM CHANNEL
ic-t90a.pdf (3.3 MB)
Hello John,
Someone has already posted the manual in the email chains. I have copied the entire group because I believe this procedure to be usable for all transceivers in general (only the manual orientation and page numbers will change) and therefore might be of some use to others. It is strongly recommended you have a complete copy of the manual with you but as an absolute minimum, all the pages referenced below.
The ICOM T-90 is an excellent transceiver. Avoid strain on the antenna connection as it may loosen and damage the internal connection to the antenna connector. SMA connectors in general are not near as forgiving of rough treatment as the BNC connectors or Motorola style threaded posts. They do work well and are reliable with careful handling.
To program repeater frequencies you need three points on information regarding the repeater you are trying to program operation for.
- Repeater transmit frequency (147.00 mHz
- Repeater offset frequency and direction
- PL tones for transmit and optionally for receive.
In general, I use little post it tabs to flag each of these sections in the manual, then program in the order indicated above.
Manual is located here:
http://icomamerica.com/en/products/amateur/handheld/t90a/default.aspx
Page 29 demonstrates how to set up repeater operation. Please note that some repeater operating on band edge frequencies (x.000, etc.) may have offset different from default offsets programmed in transceiver (auto repeater function page 33).
Page 70 is the start of the tone setting sequence.
Also reference page 11 Display layout and indicators (this will help in determination that transceiver is set correctly.
For a handheld you will also wish to transmit with highest power: See page 28.
Also set squelch level to minimum needed, see page 22.
Set time out time to 90 seconds, this will keep transceiver hung in transmit from killing the net operations. See page 76.
Then test (don’t kercunk the repeater, ID and request radio check). Depending on time of day, it make take a few trys to have a response. If there is someone that can help, call in advance and set up a testing schedule. Don’t wait till Saturday morning, please!
Last item: Once working, know how to lock the keyboard to prevent unscheduled programming changes. See pages 7-10 for details of keyboard and key functions.
If you wish to store this programming in a memory channel, please see 35-44.
73
Richard
KD5URB
What radio is it and do you have the programming cable for it?
Jerry
I’d start here:
Ouch that’s $49 bucks plus tax and shipping…
I’d start with the manual and if that didn’t work I’d consider the RT System software or getting a radio that is easier to program…
Here is a link to the manual…
Pages 97-98 has a Quick Reference Pocket Guide
But it doesn’t say how to program a tone… How could they have skipped that?
Page 71 covers how to set Tone/DTCS Squelch in 4 easy steps…
73 Dallas N4DDM
Whatever you do, don’t fall victim to “paralysis by analysis.” Go ahead and
buy/build one and start tinkering with it. This is a learn-by-doing hobby.
No politician or scholar assured your freedoms.
A Soldier, Sailor, Marine, Airman, or Guardian did!
