AAR Review for 4-4-20
Greetings,
Over the past 10 days, my paying job jumped in my way to get you the AAR reply! The ARC is planning on a drill May 30th.
Stay up for details.
Thanks,
Joe, KB5DTS
AAR reply 4-4.docx (15.2 KB)
Thanks Joe for the write up
I can tell you Brazos Co ARES will be doing our part in the up coming exercise.
We operate the Red Cross Station N5BRV in Bryan , Texas.
Ron, N5SBN
DST lead Bryan office
Brazos Co ARES EC
Joe ,
I tried to find K5SOC could not find it on winlink o did find a KE5EOC I believe but not K5SOC will try again later we are in Victoria but I have something wrong with the settings on the range of stations I’ll check it out I did find station all they way up to Katy but we will see.
Noel Villarreal - KD5PMU
Texas RACES DRO 17
Victoria County ARES AEC
Question Noel. Can you send messages using RMS Express besides packet such as ardop or the newest one called Vara Hf? The both use either Signalink or other soundcard interfaces with the software.
Wish you had Vara FM capabilities on your two meter radio so we could practice.
K5SOC is the callsign for the Texas State Races headquarters on N. Lamar in Austin – it is part of TDEM
I can do winmor and ardop I did send you a message ardop thru HF Didn’t try VARA on HF yet that’s my next project yeah I have a signallink to my HF radio but I have a kamtronics KAM plus on my VHF radio tried VARA FM but couldn’t get it to work with the KAMtronics so I can try VARC but only HF only at the moment .
Noel Villarreal – KD5PMU
John ,
Yes Sir think Joe mentioned it a while back since both Joe & myself are RACES members he was trying to see if we could find it on winlink .
Ok noel. I can do HF and Vara FM but have no one to try Vara FM with st the moment.
Let me know if you need help setting up Vara FM with the two meter radio. Kantronics won’t work with vara FM. You need a Signalink or something similar.
Ok I have a Signallink for my HF but I still need to get a signallink for 2 meter really hadn’t thought of using a signallink on 2 meters until VARA FM came along ive always used as kantronics and done PACKET for local so I need to get one for 2 meters in the future.
Yes, K5SOC is the call sign for the State Operations Center, TX RACES/TDEM
It was operational during the drill however conditions were not great for
propagation.
K5SOC-10 is the call for the RMS winlink packet and Vara FM station,
145.070 mhz.
K5SOC-10 is listed on the winlink data list and operational most of the time
with good coverage around the Austin area.
73's de
Amateur Radio Station
W5DVG
Patrick Rogers
13219 Briar Hollow
Austin, Texas 78729
Williamson County EM10cl
512-217-2251
ARRL, the national association for Amateur RadioT
TX RACES - Texas Division of Emergency Management - State Operations Center
K5SOC - Volunteer Radio Operator
TX RACES DRO Capitol District - Austin
TX RACES ASST DRO District 12 - Austin
Travis County ARES (Amateur Radio Emergency Services)
